Witam rozładowany akumulator spowodował że nie mam kodu do radia Clarion takie numery:
PU-2294A (C)
C700000001624
Z góry dziękuję za podanie kodu jeżeli będzie możliwe.
PEUGEOT PU-2294A (C) kod do radia
kod 2252Spec pisze:Witam rozładowany akumulator spowodował że nie mam kodu do radia Clarion takie numery:
PU-2294A (C)
C700000001624
Dziękuję za tak szybką odpowiedź, jutro dam znać czy kod prawidłowyAdmin pisze:kod 2252Spec pisze:Witam rozładowany akumulator spowodował że nie mam kodu do radia Clarion takie numery:
PU-2294A (C)
C700000001624
pozdrawiam.
Hello
NEED Kod* WITH RADIO CODE PLEAS from Peugeot?
Model: PU 2294A (C)
Serial no.: CLO40151011550 C
Thank you very much
:roll: :-?
Model: PU 2294A (C)
Thank you very much
:roll: :-?
Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing.ABITIBI.SK pisze:Hello
Model: PU 2294A (C)
Thank you very much
:roll: :-?
(Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio.
CLARION
New no.: C 70000003656
:idea:
:idea:
Model: CLARION PU 2294A (C)
No.: C 70000003656
Thank you very much :?: :?:
No.: C 70000003656
Thank you very much..... ;-) Thank you very much :mrgreen:
I know what to do so I can enter the code when I'm still on: 7 ERROR
Please note that code entry is only possible when "CODE IN" is shown in the display. If the display continually shows "WAIT" then the unit may be codelocked and will need to be left switched on up for up to two hours to reset before another code entry attempt is possible.ABITIBI.SK pisze:I know what to do so I can enter the code when I'm still on: 7 ERROR
Witam. Mam taki sam problem
CLARION
pu-2294a(c)
NO. C70000006345
CLARION
pu-2294a(c)
NO. C70000006345
A jeśli na radiu widnieje napis " 4 ERROR" co zrobić, żeby wpisać kod?
Wygląda na to że kilka razy wpisałeś błędny kod spróbuj zostawić radio pod zasilaniem na ok godzinę być moż po tym czasię będzie możliwe wprowadzenie kodu w niektórych modelach kod wywoływało się trzymając dłużej przycisk band jeśli się nie odblokuje to czeka cię wizyta w serwisie.14mateusz86 pisze:A jeśli na radiu widnieje napis " 4 ERROR" co zrobić, żeby wpisać kod?
