Po wymianie akumulatora radio żąda kodu.
BP 3349 4722 8876
MM CD-K 7 643 349 318
Dziękuję za wszelką pomoc i pozdrawiam.
Kod do radia Blaupunkt w Micrze
kod 9864olko71 pisze:Witam.
BP 3349 4722 8876
Post the 14 character Serial Number beginning BPxxxxxxxxxxx found stamped in the metal casingBuzo pisze:Hi can you Kod* me with code for the radio for my car
Radio model is 7643349318 And serial number is BP33494278786
Thanks
BP33494278786?
Ok, so code is BP334947278786DEKSTER pisze:Post the 14 character Serial Number beginning BPxxxxxxxxxxx found stamped in the metal casingBuzo pisze:Hi can you Kod* me with code for the radio for my car
Thanks
BP33494278786?
Code 6669 or 0669Buzo pisze:Ok, so code is BP334947278786DEKSTER pisze:Post the 14 character Serial Number beginning BPxxxxxxxxxxx found stamped in the metal casingBuzo pisze:Hi can you Kod* me with code for the radio for my car
Thanks
BP33494278786?
DEKSTER pisze:Code 6669 or 0669Buzo pisze:Ok, so code is BP334947278786DEKSTER pisze: Post the 14 character Serial Number beginning BPxxxxxxxxxxx found stamped in the metal casing
BP33494278786?
Thank you, will check tommorow
