Halo
zbyt wiele, aby poprosić o kod clarion pu 2325,
seria CL0410Y0035890
dziękuję
FrantiÂ?ek
code clarion pu 2325
Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing.feron58 pisze:Halo
dziękuję
FrantiÂ?ek
(Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio.
Podaj numer zaczynający się od C 7000000 + + + +
